Project data & BIM
11 favorites to 12 favorites
Is there a way to transfer all or most of my favorites settings that were based off of V11 library to V12 library? It would be quite time consuming to save new favorites in V12.
And or saving a previous template made in V11 to V12 with the V12 library etc?
And I guess the same with layers, line types, fills etc.?
Thanks,
Jim
54 REPLIES 54
TomWaltz
Work environments are a little trickier to deploy. It's not like a template where you just tell Archicad where it is.
You have to place them on each machine (either with a custom installer or a disk imaging software) and then make sure each user is loading them.
If you're a Mac firm, then Apple Remote Desktop is awesome for that.
Tom Waltz
TomWaltz
matthewjj wrote:
What I am suggesting is that it is better to begin with a graphisoft template. First blitz all the stuff that you don't need. Then use attribute manager to import layers and other stuff that is specific to your setup.
The problem with that method is that all your custom View Sets, Favorites, Tool Defaults, Publisher sets, Model View Options, and story structure gets blown away. That's the stuff that's hardest to recreate.
You're better to do the reverse: Start with your own template and use Attribute Manager to import anything good that might be in the Graphisoft template.
It was during the same AC version transition that I noticed our office standard work environment did not include any of the new AC11 features like Virtual Trace in the menu bars. Why? Because if you don't start with the graphisoft template you will have no idea what you are missing.
None of that's in the template, Whether you start with yours or Graphisoft's, that's still in the Work Environment.
I'm guessing you made the mistake of importing your Work Environment from a previous version of Archicad into a newer one. When you do that, none of the new commands are visible.
Tom Waltz
TomWaltz
Link wrote:
I tend to import my old profile and use the New Commands drop down option in the Work Environment dialog to add to them. Maybe Ben will suggest a better or alternative method?.
I have to admit, when I jumped from 25 users to 180, I stopped creating custom work environments. It was much easier to have menus that matched the user manuals and online information.
Tom Waltz
matthewjj
Strange things happen when you blindly migrate files from version to version...
We have a project that we migrated from AC11 to AC12. It worked fine for a while, but now, if you make a few changes then jump to another window (like a section or detail) it locks up. You have to kill the AC12 process and open it up again. This has happened seven times this morning alone. This happened two weeks ago on a different project that was migrated from AC11 to AC12. Has anybody else seen this kind of behavior? Is it fixable?
Jay Rennemeyer - full article here - http://archicad-talk.graphisoft.com/viewtopic.php?t=24108
As Karl pointed out earlier to the poor guy who start this thread, many of the new 12 objects have to be recreated to take advantage of the new features anyway. This is also true of the additional features in the Model View Options, Tool Bar, Menu Items, etc. For our firm we have found it is more straightforward to start with the GS template blitz almost everything and add our stuff into it. It's clean and reduces potential problems like the guys in paragraph 1 are having.
Let's not forget why this conversation started...
Well so far importing my previous favorites from V11, all cabinets, windows, doors and some misc other library parts are all greyed out so I assume those V11 favorites parts don't have the same GUID as the V12.
Some late nights ahead of me of redoing favorites.
Jim
to which Karl replied:
Replacing Favorites for any object-type tools is a slow, manual process that even parameter transfer cannot solve because of the types of changes that have been made... Only the AC 12 library parts 'know' about partial wall display (core only, etc) and so all old Window/Door Favorites have to be replaced if that functionality (and lots of other new 12 window/door functionality) is desired. No easy way around it.
Karl you seem completely at odds with your own statements here. In one case telling someone they have to rebuild their favorites the hard way, while advocating a complete shoot from the hip mentality about version migration, which get you back to the guys in paragraph 1. I am frankly very disappointed by this and the fact that you resorted to attacking my intelligence.
matt johnson
archicad since 2004
imac 27, 4.2 GHz Intel i7, 16 GB RAM, radeon 575 4 GB, macOS 10.14.6
imac, 4.0ghz i7, 16gb ram, Radeon M9 390 2GB, OS X El Capitan
TomWaltz
matthewjj wrote:
Karl, I can assure that I am NOT the one who is confused.
From what I've seen, yeah, you are. You have some very odd ideas you have about templates, libraries, and work environments.
There's no reason to recreate objects, tool bars, or anything else from version to version. Update or modify, maybe. Recreate, no.
How many Archicad upgrades have you actually been through? How many of them have gone well for you?
What custom content do you have in your template? Maybe it's easy for you because you don't have as much in it as other people do.
Tom Waltz
matthewjj
Dude, now you are just being mean.
I never said to recreate them. I just said to use the ones that come out of the box and modify them to your liking.
Started using Archicad 8.1 in 2004. They have all gone very well. I beta tested 9, 10, 11 and 12.
matt johnson
archicad since 2004
matthewjj
http://archicad-talk.graphisoft.com/viewtopic.php?t=23615
]I loaded AC11 and there is no option in the Palettes for either the "Trace and Reference" or "Check Markers" tools. I went into the keyboard commands and found Trace and Reference but even when I hit the command nothing happens, nothing pops up. This is so odd because in my other office I've been using AC11 all year. I've never seen this happen. - some dude named dwyss
I'm am confused:
Tom said this:
I really hate that install option. It's the "You don't REALLY want to use the new features, do you?" button.
Karl said this:
I hate the import option as well, since many users blindly use it.
matt johnson
archicad since 2004
Matt, I'm really sorry that you do not understand the issues and differences involved in templates and work environments and the most productive ways of moving forward, version to version, but a separate thread with a focused discussion would be more appropriate than continuing this discussion in this hijacked thread.
Please make your next post in a new thread, OK? Posts in this thread need to get back on the topic of migrating Favorites, please. I apologize for my part in taking us off-topic.
Thanks,
matthewjj
I agree with Karl. There is no easy way around it. If you want to take full advantage of the new AC12 library it is best to replace outdated favorites with new ones.
matt johnson
archicad since 2004
TomWaltz
matthewjj wrote:
Tom and Karl are talking from both sides of their mouths:
Tom said this:
Karl said this:
We both said we hate this install option. Most recently, I called using that option a mistake. How is that contradictory?
It loads an old work environment into a new version of Archicad. That's a bad thing.
If you think we're talking about templates in these statements, then you need to learn the difference between templates and work environments.
Tom Waltz
