Project data & BIM
AC 10 - CONSTRUCTION SEQUENCE SIMULATION ?
Does the Construction Sequence Simulation feature still exist in AC10, whereby you could attribute tasks in MS Project to building elements and then run an animation having the building constructed?
I've had a quick look at AC10 and couldn't see the 'Calculate' menu where it was before... I do hope they haven't removed it altogether.
Looks like it is not included in the standard package, but has become a Goodie - you can download it from GS website:
http://www.graphisoft.com/support/archicad/downloads/goodies10/INT.html
Thanks very much Laszlo !
Rick Thompson
The calculate menu is unchanged, and exist as before.. but you have to add the menu functions in the work environment settings.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
