2023-10-01 02:49 PM - edited 2023-10-01 04:14 PM
Is Element Snap going to be fixed in the (hopefully soon to be released) upcoming compatibility Hotfixes for Archicad on macOS Sonoma? Since Graphisoft supposedly supports the current and previous version of Archicad, should we expect Hotfixes to fix this basic & essential functionality in AC25(USA FULL) & AC26(USA FULL), since AC27(USA FULL) isn't available yet?
In the clip below, I'm unable to even measure this simple geometry, since Element Snap doesn't work anymore. In case you're wondering, I'm also unable to add dimensions to the corners of this simple geometry.
https://capture.dropbox.com/INtYugrSSPVDv9DN
Good luck moving anything without invoking the pet pallet first, and hovering your cursor above it. Forget about cmd-D or right click/Move/Drag. Those just don't work anymore. The only "workaround" I've found for this (and element snap) is having any random palette floating in my workspace and running my cursor over it every time I wish to snap to something. To measure the distance between two things, the cursor must pass over random palette twice. Once per snap. Ugh. See clip below for workaround.
https://capture.dropbox.com/b8MTZXsU17FPBimd
Will other "Known Issues" also be addressed with these hotfixes for both AC26(USA FULL) & AC25(USA FULL) (the current and previous version of Archicad(USA) as of today)?
Does Graphisoft test Archicad on upcoming macOS versions? Certainly, they must have access to macOS Developer Releases, like the rest of the world, right? If they cared enough, it seems like they would be able to anticipate, identify and solve many (if not all) of the bugs, rather than sitting back, being blindsided every year while they wait for things to break and leaving it's valued customers to hold the bag...
Solved! Go to Solution.
2023-10-05 12:53 PM
Hi Jeff,
Thank you for sharing your thoughts.
We are continuously testing the new macOS versions and have participated in the beta program as well.
We are aware of this issue and are planning to fix it in the next update of Archicad 26. The phenomenon is already fixed in Archicad 27.
For more information about the Known Issues and compatibility by different versions please read our article.
Kind regards,
Norbert Kucsma
Technical Support Engineer
2023-10-05 12:53 PM
Hi Jeff,
Kind regards,
Norbert Kucsma
2023-10-05 01:19 PM
Hi Norbert,
Thank you for your reply. It is much appreciated.
