PT
Darwuhr
AC26 Zone Favourites issue
Hi there,
Since AC26 Zone favourites do not transfer Zone categories, i.e. if I draw a zone with category X, and then select a zone from the favourites palette that has assigned another zone category, it will again show category X.
Anyone had this issue and have resolved it?
1 Solution
Darwuhr
Ok, after redefining the Favourites it works. Don't know if this is a known bug.
Go to post
4 Replies 4
Lee Hankins
Have you checked your Element Transfer Settings to make sure Zone Category is selected as an option to transfer when applying favourites?
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Darwuhr
There is no Zone Category in the Element Transfer Settings options.
Darwuhr
Mikko Lahti
Thanks, we found the same bug in AC25, redefining helped.
Mikko Lahti - Helsinki, Finland
BIM specialist
Archicad user since 2004. Currently mainly using Archicad 27 and 29 FIN and INT versions on Windows 11 and MacOS computers.
