Add-ons in Template
Are there any speed gains to be recognized by unchecking some of the add-ons in a file that will never get used other than the initial load times?
Any file size reductions?
AC10-1188 US
10 Replies 10
Hi, any more info about this Add-ons in Templates, I am looking for too.
Link
It would be good to hear from GS on this, but IME there is no significant speed increase or file size reduction in unloading any add-ons.
Keeping attributes and layout data to a minimum, plus using the built-in compression makes a big difference.
This has been discussed numerous times and Search should provide plenty of results.
Link.
TomWaltz
There are some add-ons that affect file size.
For example, we removed the IFC add-ons and file sizes dropped about 25%.
If you're not making IFCs, that could be a good one to get rid of.
Tom Waltz
Ralph Wessel
AC10-1188 US
This could vary depending on the add-on's requirements. Most will only store some preferences in the project file, which will consume very little space.
Ralph Wessel BArch
Central Innovation
Link
Well I am happy to be proven wrong, but it would be nice to get some hard figures from GS on it!
Link.
There are some add-ons that check for updates, and this can slow initial loading. Doubt it affects the speed after loading, though.
Richard
AC26 (since AC6.0), Win10
Barbara Sommer
Graphisoft Alumni
Graphisoft Alumni
Add Ons do increase the filesize but only if they are being used as well.
The IFC Add On has the biggest effect, but also for example using the Grid Tool increases the filesize.
Barbara Sommer
Technical Support Team
Budapest, Hungary
archicadwiki - the ArchiCAD knowledge base
Link
Barbara, do you have access to filesize savings of each add-on?
Link.
Thanks for the replies people, that's good info. I too would be interested in see some hard numbers from GS pertaining to each Add-On. I will try to exclude a few different ones as time allows. Can't go there at the moment.
