Johann_P
Adding revisions to layout
I'm trying to understand Archicad's revision number & descriptions.
ie. Simply how to add a revision number, description and date to a sheet.
Up to now we have manually used text to write it on the layout, but this is obviously not a sustainable method....
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
Josh Verran
Hi Johann
I did quite a bit of searching on the workflow for how the revisions are supposed to work.
In a nutshell my understanding is this:
You create an Issue, you assign which layouts are part of that issue, you then assign a change to the relevant layouts.
This process causes the layouts to revise.
Showing that revision on a layouts best done using an autotext label on the master.
I've made some of those words bold as if you search them I think it will make a bit more sense.
Sorry it's more of an "idea how it works" than a "how to".
I think the autotext fields you require will be the "Issue Date" and the "Current Revision ID".
These are some links I used.
https://www.youtube.com/watch?v=WKv8o2B1KGY
https://www.youtube.com/watch?v=4smPp1s6GeQ
https://helpcenter.graphisoft.com/guides/Archicad-20/Archicad-20-reference-guide/documentation/revis...
Tracking Changes on Layouts
https://www.youtube.com/watch?v=h92jUZ8fY5s&list=PLnXY6vLUwlWVakX9gE_4eau0ClfPX1z8b&index=14
Overview
https://www.youtube.com/watch?v=-g22hWzSeJA
Revision Management Intro
First Issue
https://www.youtube.com/watch?v=aT0ub5LSXjg
Revision Management (Creating Issue History and Transmittal Records)
https://www.youtube.com/watch?v=vCvohHDvxU4
Adding items to the revision
https://www.youtube.com/watch?v=s1U4xD29K64
https://www.youtube.com/watch?v=UpSg2XzUNJU
Altering the Change Scheme
https://www.youtube.com/watch?v=_7EDqH73cTM
Showing changes on layouts
Revision Table Object
https://www.youtube.com/watch?v=Cr7RVtzx12o
Revision marker type
https://www.youtube.com/watch?v=Tk0Ag82hT3M
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
martinij
Hello
I'm not a big fan of the revisjon tool. The issue tool is nice, but the way it works with revisjons does not work well with the way we work. Therefor we have made a little workaround:
We have custom parameters for the layout book containing revisjon index, signatures, dates etc... Then there are custom text bokses on the masters that call up those parameters. So you can right click on a layout. Set the revisjon index, signatures and everything there. Then it all will be nice and propper filled out on the layout. You can even use the same parameters in the publisher to name the files with revisjon index if you wish.
I wish I would prefer to use the revisjon tool, but as of today, this workaround is better for us and gives ut better control.
Martin Isak Jansen
(I'm the one everyone at my company asks the tech questions)
www.artec.no
