2022-10-08
		02:40 PM
		2023-05-20
		12:54 AM
			Gordana Radonic
Library part was not converted properly (Pipe Types:CF Pipe - Sch 80:685148 | E417C3BC-CE55-453B-5305-EC644D023B1A)
Can't find Macro: MEP_m_RequestSystemGlobals, called
at line 6 in the 3D script of file Custom Pipe In-line Flow Device 722.gsm. (Pipe Types:CF Pipe - Sch 80:685467 | E2ABDF1F-40BB-AB6D-B6A3-636F9428BF2C)
Library part was not converted properly (Pipe Types:CF Pipe - Sch 80 - with pipe tap:689632 | 1626FF00-B2C5-35AD-AAC0-25CCD2967C38)
at line 6 in the 3D script of file Custom Pipe In-line Flow Device 715.gsm. (Pipe Types:CF Pipe - Sch 80:685148 | E417C3BC-CE55-453B-5305-EC644D023B1A)
Library part was not converted properly (M_Transition - Generic:Standard:689264 | 3078591A-8700-B200-E21A-DB2B00B644FC)
at line 6 in the 3D script of file Custom Pipe In-line Flow Device 93.gsm. (Pipe Types:CF Pipe - Sch 80 - with pipe tap:689632 | 1626FF00-B2C5-35AD-AAC0-25CCD2967C38)
at line 6 in the 3D script of file Custom Pipe In-line Flow Device 26.gsm. (M_Transition - Generic:Standard:689264 | 3078591A-8700-B200-E21A-DB2B00B644FC)
Library part was not converted properly (Pipe Types:CF Pipe - Sch 80:399494 | 019D5609-7D85-70D4-9A23-5C3BB8DB7F2E)
at line 6 in the 3D script of file Custom Pipe In-line Flow Device 154.gsm. (Pipe Types:CF Pipe - Sch 80:399494 | 019D5609-7D85-70D4-9A23-5C3BB8DB7F2E)
Library part was not converted properly (Pipe Types:CF Pipe - Sch 80:248361 | A49E19FA-9D5A-2B87-9341-6163314FDB6A)
Library part was not converted properly (Pipe Types:CF Pipe - Sch 80:778459 | 5E044D10-F75F-52CB-A03D-8ACD045A98C2)
Library part was not converted properly (Pipe Types:CF Pipe - Sch 80:444837 | 456B8914-D350-7137-9186-DFFED1B4C86C)
2022-10-10 07:44 AM
Seems like you have not loaded the MEP Library that can be found in your Archicad Program folder.
2022-10-10 01:59 PM
Thanks for your answer, but as I mentioned this is a AC25 project opened in AC26 so the same libraries are loaded (including the MEP library).
It looks more like a library macro not being available in AC26 that was used to convert the IFC hotlinks.
2022-10-10 04:47 PM
That macro is definitely in the MEP Library 25.
So if you have that library loaded, it shouldn't be missing.
It is also in the MEP Library 26 as well - so you could load that library instead.
I have no idea why it would say the macro is missing if the library is loaded.
2022-10-13 03:13 PM
Save the project as PLA in AC 25.
Then open it in AC 26.
Let us know if this worked ok?
