2022-12-23 05:51 PM
In V26 - What happened to the save Attributes as TXT?
2022-12-23 10:59 PM - edited 2022-12-23 11:03 PM
26 has the same export options as 25. I don't recall there being a TXT format? AAT is still there, as well as XML. Just launched 21... the same: XML or AAT - both of which are text.
What do you need TXT for Gary?
2022-12-24 03:24 PM
Gary:
It is still there, but need to use the Attributes Manager... command rather than Attributes... command.
2022-12-24 09:17 PM
me bad - i was using A25 work environment and of course it did not display that option!!
Thanks for shaking my boat.
2022-12-25 12:41 AM
Thanks, @David Maudlin ... that button is so obvious I couldn't see it. How strange that the export button at the top right does not offer TXT as an option...
2022-12-26 02:59 PM
It seems totally bizarre that we can't export to excel.
2022-12-26 06:19 PM
Does Windows Excel not let you open TXT files and choose how to read the data into columns? This is part of what I see on Mac Excel when opening an exported list of Fills as TXT...
2022-12-27 05:29 PM
I have never tried that ---
Thanks
