Project data & BIM
Attributes - save as TXT
gdford
In V26 - What happened to the save Attributes as TXT?
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
7 REPLIES 7
26 has the same export options as 25.  I don't recall there being a TXT format?  AAT is still there, as well as XML.  Just launched 21... the same:  XML or AAT - both of which are text.
What do you need TXT for Gary?
David Maudlin
Gary:
It is still there, but need to use the Attributes Manager... command rather than Attributes... command.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
me bad - i was using A25 work environment and of course it did not display that option!!
Thanks for shaking my boat.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
Thanks, @David Maudlin ... that button is so obvious I couldn't see it.   How strange that the export button at the top right does not offer TXT as an option...
It seems totally bizarre that we can't export to excel.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
Does Windows Excel not let you open TXT files and choose how to read the data into columns?  This is part of what I see on Mac Excel when opening an exported list of Fills as TXT...
I have never tried that ---
Thanks
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
