Project data & BIM
Building Material Schedule
David Bearss
I want to create a schedule with Building Materials. I tried setting up a simple scheme with Building Material as the criteria but there are materials not showing up and the list is randomly incomplete. Any reason some materials are not included? Or is there another way to accomplish this?
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
cuba
Could you share your scheme setup?
Apple M1 Max 32 GB Ventura
AC27
jl_lt
Ace
Check out you have the correct rehabilitation filters setup both in schedule AND the view map, as you can set the schedule in the project map one way and adjust it in the view map. This particular setting of rehabilitation messes up everything if not correctly selected.
Finally, be careful on your select criteria on what elements you want to be scheduled
Moderator.
rehabilitation filters = renovation filters ?
David Bearss
  I am still in v18 but, what is rehabilitation?
Here are some screenshots of the library report showing the missing attributes and duplicates that I am trying to correct/eliminate. If there are other ways to find and fix these I will welcome any suggestions.
It is end of year holiday. šŸ˜‰
ā€ƒ
ā€ƒ
David Bearss
Alienware 17 R5
