You could try a simple Zone to test whether it is really incorrectly calculated.
For example, a Zone that is 2x5 and its height is 1. So it Volume should be 10.
Does it give you incorrect results then?
It you recreate the Zone from scratch, does it still give you the incorrect results?
Also, there are Zone-related settings in Project Preferences. Any chance those are affecting the result?
