qingdom
Cannot add measurement unit to length property
I have created an expression for the zone stamp to show the elevation, but it misses two things:
1. I try to add a + sign in front of the number to show it is upper than zero (and it is not showing on the stamp)
2. I try to add to show CM at the end of the number but it says syntax error.
How can i show these two on the zone stamp?
Thanks
AC27 INT | WIN10
14 Replies 14
David Lukacs
If you start mess with IF, maybe you want to add a "-" sign as well.
IF ( {Property:Paramètres généraux/Altitude inférieure à Zéro du projet} > 0 cm; CONCAT ( "+"; STRCALCUNIT ( {Property:Paramètres généraux/Altitude inférieure à Zéro du projet} ); " cm" ); CONCAT ( "-";STRCALCUNIT ( {Property:Paramètres généraux/Altitude inférieure à Zéro du projet} ); " cm" ) )
qingdom
Yes it is string, I tried in length and still the same error result. What should i choose?
AC27 INT | WIN10
Yves
it is not necessary the sign "-" is automatic
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Yves
Try to import this property
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
qingdom
This is it. Thank you all.
AC27 INT | WIN10
