2017-03-07 10:37 PM - last edited 3 weeks ago by Laszlo Nagy
2017-03-08 01:36 AM
2017-03-08 02:12 AM
Barry wrote:Hi Barry thanks for the reply. I realised I was using my old profile from a previous job sorry!
Is it because it is off on a second screen somewhere or has been dragged beyond the limits of your only screen?
Try re-applying your Work Environment or apply the Standard WE to see if it comes back to a default location.
2017-03-08 02:32 AM
2017-03-08 02:41 AM
2017-03-08 02:57 AM
elliott wrote:It has nothing to do with the files you have open.
I'm using 5025 NZE by the way. None of my old plans show the change manager palette.
2017-03-08 03:03 AM
Barry wrote:Thanks Barry.
I am not sure what gathering windows is but the Change Manager is a palette in Archicad so I don't think it will respond to any windows OS commands.
Try reducing your screen resolution then open Archicad.
Now increase your screen resolution back to maximum and you may find any lost palettes.
Applying a standard WE should have reset the palette position as well.
If you ever modify the WE and want to keep those settings be sure to save a new or update an existing scheme and also the main profile.
Never leave anything as 'custom'.
This goes for layers and Model View Options as well.
2017-03-08 04:14 AM
2017-03-08 04:26 AM
