Project data & BIM
Changes in Module Text not showing after update
I have placed a drawing (originally a dwg saved as an ArchiCAD file and edited/changed/saved/etc.) as a hotlinked module into another solo project.
Everything is fine, it scales correctly and everything looks right, but some of the text is the wrong font, color & size.
I have gone into the original, selected those items, changed the font and size -- they change on the original, but they won't change when I update. I have looked for locked layers and other settings that might affect it, but to no avail.
What am I doing wrong?
5 REPLIES 5
What do you mean by 'it scales correctly'?
As far as I know a Hotlinked Module cannot be modified, it cannot be scaled, it is treated as a locked group.
Maybe it is not a Hotlinked Module anymore.
Could you clarify this for me?
__archiben
more questions:
is it a dwg 'xref' or a PLN 'hotlink' module that you are linking into your project file?
are you using teamwork? -> you need to be signed into ALL the elements of the external file to update it.
when you say change in the "original", do you mean the dwg or the modified PLN? -> your translator could be mapping fonts and colours incorrectly if it is the dwg you are making the changes in.
are you sure it's updating? -> you could have set the modules to "manual update" in your preferences and therefore need to use the hotlink manager to carry out the update
~/archiben
b e n f r o s t
By scaling, I meant that if I changed the plan scale the module changed scale correctly as a whole. Sorry for the confusion.
As it turns out, I am just an idiot.javascript:emoticon(':oops:') I found that there were several layers from the original dwg that had text on them unexpectedly and I had to find all of them and change them. It all came out right.
I apologize for taking up valuable space on the board, but I learned a couple of things from your replies.
Thanks!
Thanks for letting us know, we are at least not left in a mystery of what could have been wrong.
Djordje
Don't
The most "obviuos" mistakes can waste you hours ... ever reinstalled the sound system and spent hours cursing before relaizing that the mute is on? 😉
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
