‎2010-02-04
12:32 PM
‎2023-05-30
12:47 PM
Rubia Torres
‎2010-02-04 01:02 PM
‎2010-02-04 01:03 PM
‎2010-02-04 01:30 PM
NeckoFromSarajevo wrote:Thanks - close, but not quite - the end of grey inner leaf/wall intersects in a different position - strikes a corner, not just an edge. Also does not give return/stop end to outer brick leaf
i hope that i understand right
this is what i get !
---i didnt understand right---
‎2010-02-04 01:32 PM
laszlonagy wrote:Thanks, that worked!.
The last time I had such a problem I took the problematic intersection, created a Custom Profile of it and assigned it to a Column. Then placed the Column into the intersection. The good thing is that since the fills are the same they blend nicely. Also the Column cuts itself out of the Walls automatically. Worked for me.
This is better than trying to use a polygonal Wall because you would have to use several polygonal walls since there are several skins involved.
‎2010-02-04 06:05 PM
