2 weeks ago - last edited 2 weeks ago by Barry Kelly
Hi, hi
How do you guys manage attribute manager efficiently between master file and all the hotlinks?
We find it quite challenging to keep attributes same in master file and all hotlinks, especially because multiple people work on multiple hotlinks in teamwork.
It would be great if there would be only one attributes for all files, somehow connected, so that when we change some material in that file, it changes in all the others as well.
What are your thoughts on that?
Solved! Go to Solution.
2 weeks ago
Yes it is on the roadmap for a future version - central attributes.
If others must create new attributes, then they must inform the rest of the team to update all associated files.
There is no easy way at present, but it all comes down to communication.
You may even want to assign just one or two people to be responsible for new attributes.
Don't let just anyone create them willy nilly.
If they do they must let everyone know.
2 weeks ago
Hi, oh yes central attributes would be great, I am looking forward to.
I also just read this article: Attribute Management of Hotlinks - Graphisoft Community - having a separate attribute.pln would also make sense.
Thank you!
2 weeks ago
Benddek Gászpor gave a demonstration of the Attribute PLN method during the first day of the Building Together Learn event last week. The session is titled "Central Attribute Management in Archicad 27". I'm not sure if this link will work, if not you can probably search for it.
https://events.graphisoft.com/event/building-together-or-learn/planning/UGxhbm5pbmdfMTYwODk0NA==
2 weeks ago
Thank you!
Actually the link dioesn´t work, maybe the session is private?, because I don´t find anything under "Central Attribute Management in Archicad 27"
2 weeks ago
I signed up for the event, and received a link to the recordings afterward. I'm not sure if Graphisoft will be posting those for everyone or not but I'd guess they will.
a week ago
Oh, I see. well is not available now, so I ll just wait that somethings comes on youtube 🙂
a week ago
I received an email today advertising the event recordings which appears to be targeted to all Archicad users. Give it a try:
MDc1LVhNTS0xODkAAAGPkBWfqhrFI6iLfXzGvMrZyGNMmKTavxlqkb3NFv_dPQXkfQQkmSvMAhk9muKcXHxnUFN_xvg=
