Project data & BIM
Crashed BIM server
So unfortunately we have a crashed BIM server and now I dont really know how to restore it on another machine.
I have access to all the original files on the crashed machine as well as a bunch och backups in the form of .BIMProject files.
What im trying first is to restore from those files. In the help it says this:
"Download Snapshot File, then Import to any BIMcloud
If you want to work with the project or library on a different, functioning BIMcloud: download the snapshot file, then import this file to a different BIMcloud.
1.From the Navigator of the Projects page in BIMcloud Manager: Select a project or library.
2.Open the Snapshots panel.
3.From the Snapshots list, select a BIMproject or Library snapshot.
4.Click Download.
5.Choose a folder to which to save the snapshot.
6.Import this snapshot to a folder on any functioning BIMcloud, using the Projects page of its BIMcloud Manager."
But I dont understand how it works. In the new bim server I cant download any snapshots at all because it is brand new. What should I do with my .BIMProject files?
Is it really possible that no one knows how to restore backups!?
Hello Freber,
Into your bim cloud interface, click on this...
Then clic on :
- Rollback to roll back
- Download to take your previous project on your computer (You will be able to check it before to share it)
Christophe - FRANCE
Formateur Archicad indƩpendant Ơ NANTES
Archicad 15 to 29 FRA FULL
