Custom door leaf displays incorrectly as a flat panel door in a schedule
I have a pocket door (#D09) with a custom door leaf that will not display correctly in the schedule. All of the doors have a "Lynden Alki" custom door leaf, however the pocket door shows a plain, flat panel door in the schedule. It is the standard Graphisoft pocket door object "D1 Pocket 27" and it appears correctly in 3D or section views (from both sides), so I'm not sure what's going on or how to fix it. The handle does show correctly. Any ideas how to fix this?
Operating system used: Windows 10.0.19045
Graphisoft Certified BIM Manager
AC27 USA - build 6000 - HP ZBook 15 G6 - Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz, 16GB RAM - Windows 10 Pro
1 Reply 1
Has anyone else had this happen or know of a solution? It seems to happen only with the pocket door object. The 2D elevation view is also displaying incorrectly as a plain, flat panel for a french pocket door, although the plan view is correct, and it also displays correctly in 3D and section view.
