Project data & BIM
EXTERN ELEMENTS
miquelarquitecte
It is absolutely ESSENTIAL AND URGENT that in external elements, such as modules, dwg, images,.., there is the possibility that these inserted elements maintain the link but are NOT loaded. In AutoCad it has been solved for decades. This is very interesting in large projects or with many external elements because they are only loaded when they are needed and not always. This makes the size of the files not so large and increases the speed of work.
Thanks
1 REPLY 1
This sounds like a wish so I would suggest that you use the official Wishlist where people can vote for your wish to show their support, and if there is enough support for the wish, it can be submitted to the Graphisoft Product Team for consideration:
https://community.graphisoft.com/t5/Wishlist/idb-p/wishlist
Setup info provided by author
