2005-12-01
05:15 PM
2023-05-30
01:02 PM
Rubia Torres
2005-12-01 05:40 PM
Tom wrote:That should do it. Unless some elements/layers are locked? The other consideration: If the layer you want to switch to is shown when you open the dialog, OK'ing that doesn't do anything. You have to switch it to some alternate layer, then switch it back (Like any attribute in a settings dialog).
I want to put them all on the same layer with one command.
When I select them, I use the little hammer on the info box and see all the different entities included in the selection set. All very nice.
I change the layer to the one I want.
2005-12-02 07:37 AM
