kjell syryn
Error: the number of arguments is not correct for this function
When creating a Expression with 2 IFS i get the error "the number of arguments is not correct for this function". What dose this mean and how can i solve this
1 Solution
Make sure it is following the correct format.
IFS(argument_1, result_1, argument_2, result_2, argument_3, result_3)
You can add as many arguments/results as you want.
Go to post
5 Replies 5
Jimmzs
Hi, I'm getting the same error and I think the syntaxis is ok. Can you help me with this?
Jim
What happens when you remove the last ... ,0
It is not part of the argument.
Xandros
As additional information:
if you like to add a result (0 in your expression), if none of the other conditions are met, you can do it by adding a TRUE as last argument:
IFS ( TRANSECTO = "T3", 3, TRANSECTO = "T4", 4, TRANSECTO = "T5", 5, TRUE, 0 )
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
Jimmzs
Thank you so much. Indeed I wanted the "0" as the result if any of the conditions were true.
