Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Project data & BIM
SOLVED!
Error: the number of arguments is not correct for this function
kjell syryn
When creating a Expression with 2 IFS i get the error "the number of arguments is not correct for this function". What dose this mean and how can i solve this
1 ACCEPTED SOLUTION
Solution
Make sure it is following the correct format.
IFS(argument_1, result_1, argument_2, result_2, argument_3, result_3)
You can add as many arguments/results as you want.
5 REPLIES 5
Solution
Hi, I'm getting the same error and I think the syntaxis is ok. Can you help me with this?
Jim
ā€ƒ
What happens when you remove the last ... ,0
It is not part of the argument.
As additional information:
if you like to add a result (0 in your expression), if none of the other conditions are met, you can do it by adding a TRUE as last argument:
IFS ( TRANSECTO = "T3", 3, TRANSECTO = "T4", 4, TRANSECTO = "T5", 5, TRUE, 0 )
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
Thank you so much. Indeed I wanted the "0" as the result if any of the conditions were true.
