‎2025-01-21 12:02 AM - last edited on ‎2025-01-21 12:10 AM by Karl Ottenstein
Hi All,
Is there a way to export a csv or an excel of all the hotlink module names and file paths in a project?
Sam
Solved! Go to Solution.
‎2025-01-21 01:51 AM
not exactly what you're after, but in the 'Hotlink Module Manager' you can create a HTML file showing all linked hotlinks and their source.
‎2025-01-21 01:36 AM
You can create a schedule with a criteria that is looking for Master ID is not - leave value blank.
Then add a field to list the 'Master ID'.
Merge uniform items and you should have your list which you can 'save as' an Excel file.
‎2025-01-21 01:54 AM
Thank you Barry,
It is a good idea. The computer just spun after I tried it. There are a lot of hotlinks in the file.
Sam
Thank you Mitch,
I have done this. This should help a lot.
