Project data & BIM
Export a List of Hotlinked modules?
SAM-PBD
Hi All,
Is there a way to export a csv or an excel of all the hotlink module names and file paths in a project?
Sam
MitchD
not exactly what you're after, but in the 'Hotlink Module Manager' you can create a HTML file showing all linked hotlinks and their source.
4 REPLIES 4
You can create a schedule with a criteria that is looking for Master ID is not  - leave value blank.
Then add a field to list the 'Master ID'.
Merge uniform items and you should have your list which you can 'save as' an Excel file.
MitchD
Thank you Barry,
It is a good idea.  The computer just spun after I tried it.  There are a lot of hotlinks in the file.
Sam
Thank you Mitch,
I have done this.  This should help a lot.
