Tom Krowka
FAvorites and layers
I've noticed this problem on several projects and wonder if I'm doing something wrong. I save electrical symbols with their appropriate layers, etc. When I load the .prf file in another project that has the same layers, many of the symbols either has the layer "missing" or have defaulted to the Archicad layer. Any trick to this? I'm tired of redefining. Are favorites common across different versions of Archicad as well?
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
10 Replies 10
rjwilden
Good question;
I have never been able to work our how to tag layers to favorites. And I also think this is important.
Richard.
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
Laura Yanoviak
Tom wrote:
...or have defaulted to the Archicad layer.
I notice that this happens if the original Layer of the Favorite is unavailable in the current project. Even if the Layer's have the same name, they may not have the same internal ID -- could this be the problem?
Tom Krowka
So that means unless you work from the same template or .pln for every project, favorites won't work. It would appear that the layer setting for favorites won't transfer across projects otherwise. unless you can change the layer ID. Which is beyond my knowledge.
[email protected]
www.walshkrowka.com
Laura Yanoviak
You need to manage Attributes -- this is nothing new, although a touchy subject for most. ArchiCAD recognizes most attributes by their index number, not their name, to speed processing time. Until GS gives us better control over Attributes, you have to rely on a good Template and the Attribute Manager.
TomWaltz
Shouldn't you be working from templates anyway?
Tom Waltz
Tom Krowka
We do, but have added some layers which we have not added to the template. So it has gotten left behind....and did not know about the ID numbers....guess I'll go back and update the template.
I wonder what will happen when AC11 comes out. Will templates and favorites transfer from one version to another?
[email protected]
www.walshkrowka.com
As well as ever. There is no change (yet) in the joys of attribute management.
Laura Yanoviak
I just opened our AC10 Template in AC11, and appears to have transferred without any (apparent) errors -- even the S/E Favorites transferred to the appropriate (Section or Elevation) Tool.
TomWaltz
The transition from 10 to 11 seems a lot easier than 9 to 10.
Tom Waltz
