2007-06-04
10:26 PM
2023-05-30
12:58 PM
Rubia Torres
2007-06-05 12:27 AM
2007-06-05 01:40 AM
Tom wrote:I notice that this happens if the original Layer of the Favorite is unavailable in the current project. Even if the Layer's have the same name, they may not have the same internal ID -- could this be the problem?
...or have defaulted to the Archicad layer.
2007-06-05 03:30 PM
2007-06-05 04:24 PM
2007-06-05 04:49 PM
Tom wrote:Shouldn't you be working from templates anyway?
So that means unless you work from the same template or .pln for every project, favorites won't work. It would appear that the layer setting for favorites won't transfer across projects otherwise. unless you can change the layer ID. Which is beyond my knowledge.
2007-06-05 04:56 PM
2007-06-05 06:54 PM
Tom wrote:As well as ever. There is no change (yet) in the joys of attribute management.
We do, but have added some layers which we have not added to the template. So it has gotten left behind....and did not know about the ID numbers....guess I'll go back and update the template.
I wonder what will happen when AC11 comes out. Will templates and favorites transfer from one version to another?
2007-06-05 07:02 PM
2007-06-05 07:14 PM
