2010-09-28
01:12 PM
2023-05-26
03:22 PM
Rubia Torres
2010-10-01 02:52 AM
2010-10-03 09:04 PM
Lasse wrote:There should be no problem opening the file on a 64bit machine. The files are not changed and are fully compatible across Mac and Windows in both 32 and 64 bit versions.
I've been careful not to open the project on my 64-bit computer.
2010-10-11 09:47 PM
2010-10-12 11:05 PM
2011-04-12 05:58 PM
Lasse wrote:
Does anyone know what's the most file size consuming things to look for in a ArchiCad file.
Is it lots of imported PDF/DWG, large number of layers or other attributes, large number of views, massive amount of layout's or loads of modules ( as .mod or .pln)?
I'm asking because I need to reduce file size of a project and would like to know where to attack.
PDF's and DWG's are gone and I'm about to clear the layer list from DWG-layers, anything else I could get rid off or slim down.
The file is a TW2 file @ 1.4 Gb (uncompressed I know) and it's causing a bit of problem for my user (slow loading, occasionally chrashing).
In short, what is the best way to reduce file size?
2011-04-16 06:03 PM
2011-04-16 06:07 PM
2011-04-16 09:15 PM
