‎2025-06-29 12:44 PM - edited ‎2025-06-29 01:25 PM
Did you guys know that you can use Fills in the pattern definition of a Symbol Fill? I just accidentally found out about this when by mistake I selected a Fill in addition to a Line, Arc, and Hotspot while drawing the intended Symbol Fill pattern and copy-pasting it in the Fills Dialog. I thought only Lines, Arc/Circles, and Hotspots could be used (not even Polylines).
This capability opens up some new possibilities.
Here is an example:
Two notes:
Operating system used: Windows 11 23H2
‎2025-06-30 01:00 AM
they sure can affect performance. we have a background tree fill that makes elevations suffer the first time you open them. turning off 'true fill appearance' stops it from happening however.
