‎2023-05-01
05:33 PM
‎2023-05-20
01:02 AM
Gordana Radonic
Working on a room schedule for a project. Currently trying to get the wall finishes into the schedule. I have under properties - Zones - North wall finishes set but when I add that field to the schedule all they show up as is ---. I have it set on all the zones but they all show the same thing. I attached photos of the issue as well
‎2023-05-02 03:17 AM
Can you show an image of your schedule criteria and fields?
Copy and paste the image directly into the text you type if you can, rather than use the drag & drop box below.
That way the image shows in the message.
‎2023-05-02 03:13 PM
I got it figured out. I was using the pre-made "Room Legend" under surfaces. I redid it under elements and they showed up then.
