Project data & BIM
Finish Schedule
Fristadm
Working on a room schedule for a project. Currently trying to get the wall finishes into the schedule. I have under properties - Zones - North wall finishes set but when I add that field to the schedule all they show up as is ---. I have it set on all the zones but they all show the same thing. I attached photos of the issue as well
Screenshot 2023-05-01 at 10.28.24 AM.pngScreenshot 2023-05-01 at 10.28.39 AM.png
ArchiCAD 25.6005
Can you show an image of your schedule criteria and fields?
Copy and paste the image directly into the text you type if you can, rather than use the drag & drop box below.
That way the image shows in the message.
I got it figured out. I was using the pre-made "Room Legend" under surfaces. I redid it under elements and they showed up then.
ArchiCAD 25.6005
