KNA
Hotlink IFC morph edge settings change?
Hello,
I have a morph model with hidden edges. When I save it to an ifc file and place the ifc file as a hotlink to the model, its edge setting changes from hidden to hard. Is there a way to avoid this so the linked ifc could have the same setting as the original? The reason I´m using ifc and not module is that I have a picture on the morph model and when I move the module model in the linked file the pic moves. With ifc it´s somehow "glued" to the surface.
Thanks!
KNA
0 Replies 0
