2004-02-06
03:29 PM
2023-05-26
09:06 AM
Rubia Torres
2004-02-06 03:41 PM
2004-02-06 05:37 PM
mkopecky wrote:If they are rooms (e.g. hotel rooms of various types) and spaces, you are better off with a module. If they are, let's say, chalets of a tourist resort, you are better off with the PLNs as each of them needs separate set of documents. You will anyway start off with a PLN - whether the compelte project, that you will save the modules from for further refinement, or starting from the modules and putting them together, that is for you to decide.
We are about to start a fairly large project with multipule occurences of rooms/spaces. I was wondering if there is a difference in creating these occurences as mod files or pln files. Since you have the ability to hotlink to both (with multipule occurences), is there a difference in linking to either one? File size, flexibility, startup speed, updating, modifying, etc.? Any advantages/disadvantages to either? Thanks,
Michael
2004-02-06 05:44 PM
Djordje wrote:Thanks for the attribution Djordje, but it's Tom you are quoting.
As Matthew said, PLNs are more powerful, albeit somewhat slower. MODs are lean and mean, and both take some time to update - depends on the file sizes, and the hardware setup (network speed, machine speed).
2004-02-06 06:01 PM
Matthew wrote:OOOPS! Sorry, Tom!
2004-02-06 06:07 PM
2004-02-08 09:03 PM
Any advantages/disadvantages to either? Thanks,Micheal
Michael
2004-02-08 09:57 PM
Djordje wrote:
Watch out for the materials, fills, line types, special objects created, library usage. It should all be identical in all the parts of the whole. Use Attribute Manager for the attribute transfer.
