Johann_P
Hotlink not showing all elements
Hi all.....
We've started working with hotlinks, but seem to be missing elements in the "Master file"
I have:
1x "Master" site.
1x Module A
1x Module B
Module A and B has different storey settings.
Module A and Master Site has the same storey settings.
Module A is missing some elements in the Master Site.
Module B, with different storey settings, seem to show all the elements.
Below is what Module A looks like:
But this is how it shows in the Master Site:
This was the original storey settings of Module A and the Master Site: Same Same.
I then added an additional "top storey" to the master site and re-linked Module A, but it made no difference:
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
1 Solution
Podolsky
Ace
This is corrupted element. One node of the 3d element geometry just jump far far away.
To solve this problem there are two solutions:
1. To understand what this element is. Try to select only this element and identify. Then it can be re-created again. In very rare cases walls connection might give this glitch.
2. Open hot linked pln file in ArchiCAD in mode "safe and repair".
Go to post
6 Replies 6
Johann_P
Into the same "Master Site" is hotlinked Module B.
Module B is showing correctly, but it has different storey settings to the Master Site.
This is the Module B:
This it how it shows in the Maste Site
And this is the storey settings of Module B and the Master Site
Windows 10 Pro
Podolsky
Ace
It looks like that when you hotlink your file, you choose to show only one floor. That might be the reason of disappearing elements - because they belong to another storey.
When you create new holink, the new window appears to choose all floors or selected storey:
Lingwisyer
Guru
No warnings in the Module Manager, no purple lines in the Floor Plan?
Johann_P
Its working now.
The settings that is shown earlier in the tread are all correct.
But "updating" the hotlink didn't update the missing elements.
I deleted the original hotlink completely and re-hotlinked it.
Seems to be working fine now.
Windows 10 Pro
Johann_P
I have now developed a different challenge with hotlinks.
The hotlink shows a floor that is about 6000km long
Yes 6000km.
It seems to be part of the hotlinked module, but the object/floor doesnt seem to be in the module.
I've deleted to module, resaved the module, re-hotlinked the module, but the object still shows in the master file, but not in the module file.
Any ideas?
OBJECT IN QUESTION:
ZOOMED VIEW OF THE OBJECT:
DETAILS OF THE OBJECT
THE MODULE FILE, WITH ALL LAYERS AND RENOVATIONS SHOWING.
Windows 10 Pro
Podolsky
Ace
