‎2007-09-27
04:31 PM
‎2023-05-30
12:55 PM
Rubia Torres
‎2007-10-25 12:44 PM
‎2007-10-25 06:49 PM
‎2007-10-25 07:18 PM
Chris wrote:I think that is the only way of doing it. Demo, Exst, New layers for construction elements be them modeled or 2D, Demo and New for annotations and dimensions --results in a lot of layers but if your layer combos are right that is not much of a problem, and makes it easy to switch elements to demo and back during the design process.
Right now, I have to have a separate layer for each element type (wall-new, wall-existing, trim-new, trim-existing, etc.). Everything that's demoed goes on a single demo layer so at least that's easy. This is workable, but makes for a lot of layers and I've wondered if there is a better way.
‎2007-10-25 07:20 PM
Chris wrote:This is generally the way to do it; however I don't create a layer for individual existing elements. For instance, if it is to appear on the floor plan, it goes on A-Flor.EXST, if it is to appear on the RCP it goes on A-Clng.EXST, and if is to appear on both it's on A-Wall.EXST.
Has anyone found an efficient way to deal with existing, demo, and new elements? Right now, I have to have a separate layer for each element type (wall-new, wall-existing, trim-new, trim-existing, etc.). Everything that's demoed goes on a single demo layer so at least that's easy. This is workable, but makes for a lot of layers and I've wondered if there is a better way.
‎2007-10-25 08:58 PM
Chris wrote:I use the mark-up layers... You can choose a color (red/yellow) for the layer, and create model view options to show them in the layouts.
Has anyone found an efficient way to deal with existing, demo, and new elements?...
‎2007-11-13 07:58 AM
‎2007-11-13 08:03 AM
mc0m wrote:Why would that be difficult?
For US federal agencies you typically have to submit the final digital documents in AutoCad format with NCS layers.It makes things difficult. Is there anyone else out there that has to do this?
‎2007-11-13 05:54 PM
Steve wrote:Well, first of all you have to start with their drawings - which already have umpteen thousand layers, i.e., the building is already drawn, so you need to go on a fishing expedition to figure out what is where. So far, I've never received a set of drawings that actually complies with their own standards. (That's another challenge.)mc0m wrote:Why would that be difficult?
‎2007-11-13 07:44 PM
‎2007-11-13 08:00 PM
