2024-02-07 02:30 PM
I am looking for a way to query the handing / hinge side of a swinging door in a schedule.
I know I can create a property to enter the data manually for a door. However, if the door is part of a module AND the module is mirrored, the handing / hinge value is incorrect. I want the value to display "Right" or "Left" automatically (This situation is similar for cabinets and plumbing fixtures too.)
The alternative is to create two master units for the modules; a Right and Left version. While this would work, it would double the maintenance effort of managing the prototypes.
Thoughts?
Joe A.
(ArchiCAD since 8.0)
Solved! Go to Solution.
2024-02-07 04:10 PM - edited 2024-02-07 04:11 PM
I could imagine an expression based property, which uses the Hotlink Master-ID as a switch for a condition, might work in your case.
If you work with unique Hotlink Master-ID's or are even able to include a unique sign for a mirrored hotlink, you might look for this name / sign in your expression and react accordingly to it.
for example like this:
IF(Hotlink Master-ID="mirrored";
IFS( Hinge Side = "Left"; "Right";
Hinge Side = "Right"; "Left");
Hinge Side)
Hinge Side)
2024-02-07 04:18 PM
Great idea!
I will follow that thought process through the Hotlink Module.
(Now if only ArchiCAD could auto-detect the hinge side of a door...)
2024-02-07 05:05 PM
On the French version this parameter exists
