2022-09-02
07:48 AM
2025-01-30
04:37 PM
Molinda Prey
I accidentally found a hotlink with the wrong story and offset in the elevation, but the location is correct.
What should I do?
Do I have to delete it and do it again?
2022-09-02 02:56 PM
If the ofset of walls is incorrect you do have to do it again and save as module, and update the current one. As far as story goes, you can move entire module between stories and such.
2022-09-02 03:38 PM
The hotlink below normally has a value of 0.
There seems to be a problem while copying.
Is it impossible to edit?
