Project data & BIM
Interactive schedule export to XL
rjwilden
Can you export a interactive schedule to Excel. I cant seem to find any method or instruction for this.
Richard
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
click in the schedule to make it active, then File-Save as. It will save as a comma delimited file that Excel can import into a new document.
rjwilden
Yes that works, thanks for that.
Richard
Archicad V23:V24
Exporting to EXCEL this way works great, but I was a little unsure what a "comma delimited file" was. So for the benefit of the next person pulling their hair out trying to figure this out with zero time to wait...
To export a schedule to EXCEL:
(in v9, I assume v10 is similiar though I'm just getting into v10)
go to calculate/interactive sechedule/preview
get your schedule set up correctly
choice output to: text file
then click the create list button
Now open the .txt file in EXCEL and follow the prompts (you'll want to choose delimited, then tab as the delimiter).
BAM!! so so easy, if you know that you can do it!
Jared Banks, AIA
Shoegnome Architects
