Is there a limit in lenght for custom properties formulas?
Hi!
I was thinking about an alternative to the way my sum area python script works: https://community.graphisoft.com/t5/Archicad-Python-API/PYTHON-Sum-area-script/td-p/371704
Atm, the result of the sum is stored in each zone. The problem is that if the zone is locked, the layer is locked, the zone is a module.... the script can't work. I don't think that this is a big problem, i could work on unlocking layers and objects, opening modules, reserving elements, but I would like to test something else.
An alternative would be to store with a python/tapir script all the result in a single formula that would look like that:
-IF (ZONE NUMBER = A, value of the sum of all area with a zone nuber = A; (ZONE NUMBER = B, value of the sum of all area with a zone nuber = BETC...)  )
That would mean I could have several hundred nested Ifs.
My questions:
- Is there a size limit for a formula?
- Will I crash Archicad (and my computer?) with formulas that are computationally intensive?
Archicad 27 - GDL - PYTHON
1 Solution
And same question for the project info part, I could store all data in one info if it is possible.
EDIT: I tried with 300 values and It worked well. Lets go for a new version !
Go to post
1 Reply 1
