Project data & BIM
Layer Nightmare - bug?
DennisG
Greetings fellow Talkers.
Had the following happen to me recently - discovered it today.
Was working on some detail modules over the past few days; both as MOD files, and as imported Hotlinks with associated views in the PLN file.
Once I went back to working on the floor plans, I discovered, to my horror, that somewhere along the line every single bit of data that I had worked on up until that point had been put on the ArchiCAD layer - none of my view sets worked. In fact, it looks like the only layers remaining are the ones brought in by the module file; I went from having about 50 layers to having about 10 layers; and all but the module info ended up on the ArchiCAD layer.
I remember choosing to have the module's layers put onto the ArchiCAD layer, thinking that I'll select and change them to other layers later; what I definitely did not choose was to have all my work put onto the ArchiCAd layer, with the exception of a module that I'd imported.
Does this sound like a bug, or did I inadvertantly toggle some gawd-awful excuse for a setting somewhere, causing this to occur? Please let me know what you think so I will know how to avoid this in the future.
Thanks,
Dennis Glynn AIA
Dennis Glynn AIA
ArchiCAD-64 23 3003 USA FULL
x64 Clone PC w/Intel(R) Core i7-4790 CPU @ 3.60GHz, 3601 Mhz, 4 Cores, 8 Logical Processors
NVIDIA Quadro K620
16.00 GB RAM
Win 10 Pro x64 based PC
4 REPLIES 4
Djordje
This does sound like a bug; which ArchiCAD?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Aussie John
Did you crash? I have had most my layers dissappear once. Another time all elemants in the section view had moved to the archicad layer.
I think it was version 7. I think I was pretty mad
Cheers John
[/size]
Djordje
AFAIR this WAS a problem until 8.0 V2/R2. That is why I asked Dennis which ArchiCAD.
Please guys - ALWAYS include your version and service release, as well as OS data when you report a problem!
Djordje
HP Omen
DennisG
I apologize, guys - forgot to include my snazzy signature, which would tell you that yes, I am using the latest version of the software that is available. I uninstalled the earlier versions of AC 8, and installed fresh from the CD which arrived within the past two weeks.
And no, this was not the result of a crash in ArchiCAD. I have experienced unstable performance in PM 3.1 - it crashes more often than I'd like.
Let's see - I'll X out this box, and hopefully my signature will appear below.
Thanks all,
Dennis
Dennis Glynn AIA
NVIDIA Quadro K620
16.00 GB RAM
