Project data & BIM
Layer Purge
Is there a way to purge all unused layers?
Or, do I have to do each one manually?
4 REPLIES 4
Ted Taylor
Try the Attribute Manager under the "Options" menu
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
Thanks buddy, I knew it was right under my nose some where.
Just so I don't pul a bone head move, are the layers without a check the one I can safely delete and not worry about deleting actual drawing information (in other words I would only be deleting unused layers by deleting the layers WITHOUT a check mark)?
Thanks again
TomWaltz
Theoretically, yes.
There was a bug in the past that allowed layers with content to not have a check next to them.... delete with care!
Tom Waltz
David Maudlin
Also, any layer assigned to a tool's default settings will have a check mark. For example, if the wall tool is set to "Exterior Walls" layer, a check mark will appear next to this layer, even if there are no elements on this layer.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
