ā2015-03-27
06:44 PM
ā2023-05-25
06:32 PM
Rubia Torres
ā2015-03-27 06:50 PM
ā2015-03-27 07:17 PM
ā2015-03-30 04:21 PM
ā2015-03-30 04:42 PM
ā2023-03-29 05:50 PM
Piggybacking onto this thread...
Can Section/Elevation markers be turned off for the hotlinked file when they are visible in the project that is active?
ā2023-03-30
03:32 AM
ā2023-04-04
02:16 AM
Only if they are in a different layer to those in the main file.
And that different layer is turned off in the main file.
To clarify how hotlinks and layers work...
When you bring a hotlink in to a main file, the hotlink has a master layer.
If the hotlink master layer is turned off, all of the hotlink will be turned off.
If the hotlink master layer is on, then the other layers in the hotlink will respond normally as you turn them on/off.
If your hotlink has the same layers as your main file, then it will all work as normal so long as the hotlink master layer is on.
If your hotlink has different layers to the main file, you can control them separately - you will need to include them in any layer combinations if you want to automate them.
ā2023-03-30 03:42 AM
@Barry Kelly thatās helpful, thank you
