Project data & BIM
Layer combination intersection group numbers??
Is there a quicker way to change Layer combination intersection group numbers other then one by one?? Thanks
Aaron Bourgoin
You need the "Intersections in Layer Combinations" Goodie.
Download and Install the Goodie from Graphisoft's website: http://www.graphisoft.com/downloads/goodies/index.html
After you've done this, re-apply the Hotfix for your current build to complete the installation. It should appear as a new item in the Options Menu after you re-launch.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.27 Mac
MacOS Tahoe 26.2
Cool thanks! I will give it a go.
