2017-11-14
09:51 AM
2023-05-30
12:37 PM
Rubia Torres
2023-02-10 06:39 AM
Problem is still there in AC25.
Actually worse.
I set the desired Layer combo in the Quick Options Bar.
It flicks the name up for a split second, then turns to "Custom"
I publish a set of layouts with this cutsom layer combo setting.
half the drawings are OK, the other half has the title block layers turned off!!!!!!!!!!
GS pls fix this problem ASAP!
2023-02-15 09:21 PM
I am having the same issue. It appears to have happened after importing layer combinations with the attribute manager.
2023-02-16 01:03 AM
I doubt it has anything to do with importing layer combos. I never did that, yet the problem is there.
2023-06-01 03:36 AM
Same problem occurred for me after importing layer combinations from another file.
It seems the layers combinations got a bit confused and every possible change reverted to "Custom".
The fix for me ...
I created "New" combinations based on each existing one and appended "2" to the name. Then deleted the old ones and finally renamed the new combinations without the "2". Need to then reassign the layer combinations to each view.
AC26 MAC
