Layer combinations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-03-06
08:15 AM
2023-05-30
12:46 PM
Rubia Torres
We have one issue about the layer combinations how to use the layer combinations tool can you explain with images if any one can help to us in ArchiCad-12version.
Thanks
- Labels:
Project Management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-06 01:32 PM
For information with images, go to Help > ArchiCAD Help, when your browser opens click on the "Search" tab, and input "layer combinations" in the search box, in the results list "Layer Settings Dialog Box" will lead to detailed information.
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-06 05:14 PM
Get hold of the interactive training guides from here and follow them through when you can. You will learn a lot!
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-03-16 11:53 PM
Starting from the Menu bar click on Windows - Palettes - Quick Layers.
By null at 2010-03-16
Using the Quick Layers palette turn of every layer you don't want to see the Layer Combination your making. Then select all of the objects and using the Quick Layers palette again click Hide Others' Layer to turn off all other layers to make sure any layers not showing at the time are not unintentionally included. Now use Ctrl-L to open the Layer Settings (Model views) window. Click New, and name your new layer combination. Click OK. Now when you open the View, it will use the Layer Combination you just created. Right click on your View, select View Settings to see what Layer Combination is associated with the view.
