Hi Folks,
Newly migrated to 13 from 12.
I get a strange message every time I load libraries.
"Warning! Satellite library is in one of the active libraries."
In our office, we keep the office standards lib. on the server. Its old, has years of accumulated but commonly used parts. Each project has its own custom parts library folder, within its project folder, also on the server.
Each workstation has its own up-to-date(hopefully!) Archicad 13 Library.
Here are the questions:
1. In 13, it seems like the Projects library objects should be Embedded. But do they still reside somewhere as GSMs that can be imported into another project? Should I no longer be saving custom parts into a folder?
2. I've tried to link the Project's library folder as a linked library, but the custom objects within it are not found, even though it is a linked library. I then embed the individual objects (in schematic, so its only one or two; not a problem...yet!) I figure this is not how its supposed to work, but not sure where my mistake is.
3. Embedded objects do not remain embedded after opening AC. After saving and closing. It looses the path to the object and is listed as missing when i open the project in the morning.
Thanks.
