2006-07-25 07:20 PM
2006-07-25 09:39 PM
2006-07-25 10:10 PM
2006-07-25 11:19 PM
2006-07-25 11:26 PM
Link wrote:
The most important thing is to keep the paths the same on each computer (at least for PC - not sure how different Mac HD names affect library loading in AC10). If ArchiCAD finds the same path on any machine, you won't have to manually locate them.
Link.
2006-07-26 12:05 AM
Joseph wrote:ensure all of your machine hark disks are called the same name (this doesn't affect their "sharing" network name: System Preferences>Sharing), just the hard disk name - usually it's called "Macintosh HD" by default: don't change it.
Any Mac users have a suggestions.
2006-07-26 12:13 AM
~/archiben wrote:So it hasn't changed in ArchiCAD at all then?Joseph wrote:ensure all of your machine hark disks are called the same name (this doesn't affect their "sharing" network name: System Preferences>Sharing), just the hard disk name - usually it's called "Macintosh HD" by default: don't change it.
and if you don't want to do that you'll just have to load them all from the server!![]()
~/archiben
2006-07-26 12:32 AM
Link wrote:that would be nice. i must admit i haven't tested out AC10 in a network environment thoroughly. tom might know more . . .
I thought maybe GS would imoplement some kind of relative path like in the Drawing tool to help with that. Oh well...
2006-07-26 12:35 AM
~/archiben
2006-07-26 12:41 AM
Joseph wrote:look at the file path in your library manager . . .
Is there a way of telling that if the one loaded is on the intended computer?
