Project data & BIM
Make a hotlink module compose of two differents stories.
jespizua
Hello!
I´m trying to make a hotlink compose of two stories but i can´t select the two stories at the same time. Is there a way to do this?.
Thanks in advance!
osx 10.14 | archicad 22 | cinema4d 18 |
5 REPLIES 5
TomWaltz
It would be really nice, but no.
I feel like someone had some kind of long workaround for this a while back that used the 3D window to copy eleemnts into a module, but I also remember thinking it was almost more work than just placing two different links.
Tom Waltz
jespizua
Thanks for your quick answer Tom!.
I don't know any clever way to insert a multi-story module, but once they are in place they can be moved as a unit with the heavy marquee.
Djordje
Search Archiguide for the multistorey module tip by Akos Pfemeter.
And/or Balazs Biacs
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
jespizua
Thanks a lot Djordje! I´ll give it a try.
