ā2022-10-08 10:36 AM
I can't find merge uniform items in schedule in AC26?
I only have merge items which merges everything and i don't know why would anyone merge everything that is not the same.
Did the setting move?
Solved! Go to Solution.
ā2022-10-08 12:53 PM
This is the link to the help article that explains it all in more detail.
https://help.Graphisoft.com/AC/26/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC26_Help%2F050_Views...
ā2022-10-08 10:46 AM
If you can share a s screenshot of schedule without merging?
ā2022-10-08 10:48 AM
Of course.
ā2022-10-08 12:28 PM
I see the second column showing no. 1 should be eliminated as they are sharing the same property, that will eliminate merging all together.
ā2022-10-08 12:32 PM
But i want to merge them if they are the same size, and i want to show the quantity.
For example if there are 5 beams with same length, those 5 would merge and write 5.
ā2022-10-08 12:46 PM
Simply go to the size field and display the flag icon so it will give you a sub-total quantity and size for the merged beams.
ā2022-10-08 12:47 PM
One of the enhancements to AC26 was to do with the ability to add more control to merging of elements in schedules. I havenāt used it yet so not sure how it works.
ā2022-10-08 12:51 PM
( the ability to add more control to merging of elements in schedules )
thanks @Lee Hankins @for the info and I hope you highlight that more even with a link or a screenshot.
ā2022-10-08 12:54 PM
Having hit the merge all it merges all even those who are not the same, i don't want to merge all, only the uniform items. I did click the flag, nothing happens.
Attached screenshot after i hit merge and flag.
