qingdom
Merge uniform items missing?
I can't find merge uniform items in schedule in AC26?
I only have merge items which merges everything and i don't know why would anyone merge everything that is not the same.
Did the setting move?
AC27 INT | WIN10
1 Solution
Lee Hankins
This is the link to the help article that explains it all in more detail.
https://help.Graphisoft.com/AC/26/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC26_Help%2F050_Views...
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Go to post
14 Replies 14
If you can share a s screenshot of schedule without merging?
AC 29 INT 4006/WIN 11
qingdom
Of course.
AC27 INT | WIN10
I see the second column showing no. 1 should be eliminated as they are sharing the same property, that will eliminate merging all together.
qingdom
But i want to merge them if they are the same size, and i want to show the quantity.
For example if there are 5 beams with same length, those 5 would merge and write 5.
AC27 INT | WIN10
Simply go to the size field and display the flag icon so it will give you a sub-total quantity and size for the merged beams.
Lee Hankins
One of the enhancements to AC26 was to do with the ability to add more control to merging of elements in schedules. I haven’t used it yet so not sure how it works.
Lee Hankins
macOS Tahoe (26.0)
( the ability to add more control to merging of elements in schedules )
thanks @Lee Hankins @for the info and I hope you highlight that more even with a link or a screenshot.
Lee Hankins
Lee Hankins
macOS Tahoe (26.0)
qingdom
Having hit the merge all it merges all even those who are not the same, i don't want to merge all, only the uniform items. I did click the flag, nothing happens.
Attached screenshot after i hit merge and flag.
AC27 INT | WIN10
