Project data & BIM
Multiply Quantity using Expressions
JCCARLOS91
I am trying to calculate for parking requirements for various apartment types.
Right now, I've created a schedule that counts the number of zones plotted in each apartment unit. Ideally, one unit (meaning one zone) equals to just one count of parking. But in the 2 bedroom apartments, there is a requirement of 2 parkings per unit.
How can I create an expressions that multiplies the count of a zone into 2 or 3?
John Carlos
AC25 | iMac 2019
1 REPLY 1
AllanP
I assume that you are using different Zone Categories for apartment units
so:
add an integer property and
add the expression:
IF ( {Property:Zone/Zone Category} = "1 BED", 1, IF ( {Property:Zone/Zone Category} = "2 BED", 2, IF ( {Property:Zone/Zone Category} = "3 BED", 3, 0 ) ) )
which will give you a 0 if the value is not "1 BED" or "2 BED" or "3 BED"
or you could use
IFS ( {Property:Zone/Zone Category} = "1 BED", 1, {Property:Zone/Zone Category} = "2 BED", 2 ,{Property:Zone/Zone Category} = "3 BED", 3 ,TRUE, 0)
which will give you an 0  if the value is not "1 BED" or "2 BED" or "3 BED"
add the field from " parameters and properties"
then sum the properties,
and "Hey Presto, you have baked a cake..."
I hope this is useful.
P.S.
using if statements:
file:///C:/Program%20Files/GRAPHISOFT/ARCHICAD%2025/Help/Files/index.htm?rhcsh=1&rhnewwnd=0#t=_AC25_...
I have been using ArchiCAD continually since ArchiCAD 4.5, 4.5.5, 5, 5.1, 6, 6.5, 7, 8, 8.1, 9, 10, 11, 12, 13, 15, 18, 21, 22, 25, now testing 28
Member of Architalk since 2003, but missed the migration to Graphisoft. Melbourne, Australia
